tleung927
May 01, 2018Tutor
rbk40 WOL via internet not working
I was use D-Link and asus router before and i can make the WOL working easily (set the reserver IP and port forwarding ) but after i move to new house i need a better range router. So I choose Orbi R...
- May 04, 2018
OMG it's working finally but not by port forward.
I am using router build in VPN + openVPN + tool in windows call wakemeonlan. Everything is working now even though i am not able to make it work on iOS. I try all the WOL app + openVPN on my iphone but nothing works so far. Anyway thanks for you help.
May 02, 2018Guru - Experienced User
Remember to disable uPnP after you set up any Port Forwarding configurations...
- tleung927May 02, 2018Tutor
disable uPnP is not helping
- DarrenMMay 03, 2018Sr. NETGEAR Moderator
What modem are you using and are you using DDNS or do you have a static IP from your ISP?
DarrenM
- tleung927May 03, 2018TutorI am renting charter modem not sure what brand and modem. But I am using same modem before and WOL works so I think the problem is on router
