tleung927's avatar
May 02, 2018
rbk40 WOL via internet not working
I was use D-Link and asus router before and i can make the WOL working easily (set the reserver IP and port forwarding ) but after i move to new house i need a better range router. So I choose Orbi R...
  • tleung927's avatar
    tleung927
    May 04, 2018
    OMG it's working finally but not by port forward.
    I am using router build in VPN + openVPN +  tool in windows call wakemeonlan. Everything is working now even though i am not able to make it work on iOS. I try all the WOL app + openVPN on my iphone but nothing works so far. Anyway thanks for you help.
