tleung927
May 01, 2018Tutor
rbk40 WOL via internet not working
I was use D-Link and asus router before and i can make the WOL working easily (set the reserver IP and port forwarding ) but after i move to new house i need a better range router. So I choose Orbi R...
- May 04, 2018
OMG it's working finally but not by port forward.
I am using router build in VPN + openVPN + tool in windows call wakemeonlan. Everything is working now even though i am not able to make it work on iOS. I try all the WOL app + openVPN on my iphone but nothing works so far. Anyway thanks for you help.
DarrenM
May 03, 2018Sr. NETGEAR Moderator
What modem are you using and are you using DDNS or do you have a static IP from your ISP?
DarrenM
tleung927
May 03, 2018Tutor
I am renting charter modem not sure what brand and modem. But I am using same modem before and WOL works so I think the problem is on router
