tleung927
May 01, 2018Tutor
rbk40 WOL via internet not working
I was use D-Link and asus router before and i can make the WOL working easily (set the reserver IP and port forwarding ) but after i move to new house i need a better range router. So I choose Orbi R...
- May 04, 2018
OMG it's working finally but not by port forward.
I am using router build in VPN + openVPN + tool in windows call wakemeonlan. Everything is working now even though i am not able to make it work on iOS. I try all the WOL app + openVPN on my iphone but nothing works so far. Anyway thanks for you help.
DarrenM
May 02, 2018Sr. NETGEAR Moderator
Have you tried to make 2 separate entries for port 7 and port 9?
DarrenM
May 03, 2018Sr. NETGEAR Moderator
is it a modem only or does the charter one have a router built into it?
DarrenM
- tleung927May 03, 2018TutorIt’s modem only
- tleung927May 04, 2018Tutor
I even try change the subnet mask to 255.255.255.128
still not working .... holy xx i am thinking return this
