rscott20518
Dec 02, 2023Aspirant
RBK43-100NAS:If I factory reset my router and manually restore the settings, will devices reconnect?
My Parent's Orbi has reached a state where I can not log into the admin controls, and despite me having the serial number on hand, I can not reset the password due to forgetting my answers to the sec...
michaelkenward
Dec 03, 2023Guru - Experienced User
rscott20518 wrote:
My Parent's Orbi has reached a state where I can not log into the admin controls, and despite me having the serial number on hand, I can not reset the password due to forgetting my answers to the security questions. I'm tempted to factory-reset the router, but I want to make sure the devices that are connected will reconnect if I configure the router with the same connection password, SSID, and encryption.
It should work. But who knows what subtle settings there are in there beyond the SSID and password for the wifi?
Of course, if you made a backup of the settings before you forgot the router's own password that would make life easier.
rscott20518
Dec 03, 2023Aspirant
I don't have any backups unfortunately. I wouldn't expect my parents to even know why to make backups anyway.
There is no model number. I only see a serial number, "50U2755501CDE" and a MAC of "A040A077E6D1"
- michaelkenwardDec 04, 2023Guru - Experienced User
rscott20518 wrote:
There is no model number. I only see a serial number, "###########" and a MAC of "A040A077E6D1"I have yet to see a Netgear device that doesn't have a label with the model number.
That's in the manual. Unlike most devices, it doesn't say "Modem Number". But that's where to look.
