Aldavewebbs
Oct 22, 2023Aspirant
RBK43-200NAR
I’m looking to get a replacement / single satellite for this model of Orbi’s wire mesh series - what options do I have, which are compatible with this, now discontinued product?
michaelkenward
Oct 22, 2023Guru - Experienced User
Which Orbi routers and satellites are compatible? | Answer | NETGEAR Support
- AldavewebbsOct 22, 2023AspirantSaw this already but the product/model number I referenced is not represented in this table, unless I am mistaken?
- michaelkenwardOct 22, 2023Guru - Experienced UserRBK43 = RBR40 router plus satellites?
- CrimpOnOct 22, 2023Guru - Experienced User
michaelkenward is spot on. Netgear has a distinct pattern when creating product numbers for the residential Orbi line:
- xxRxxx indicates a Router.
- xxSxxx indicates a Satellite
- xxKxxx indicates a Kit, consisting of one router and one or more satellites.
- Rxxyyy indicates an ordinary Router, which must be connected with an Ethernet Cable to a modem or fiber ONT.
- Cxxyyy indicates the product includes a Cable modem as part of the router.
- Lxxyyy indicates the product includes an LTE modem as part of the router.
Other Netgear product families have naming conventions as well.
