borborygmus
Aug 23, 2020Aspirant
RBK43 Orbi Router and 2 x Satellites, Tri-Band AC2200 - extra satellite required
I have had this sytem for a couple of years now, has worked great in our old house. Now moving to a bigger house and I expect that I may need another satellite - which model should I buy to give me g...
- Aug 23, 2020
You can get a RBS20, RBW30, RBS50, RBS50Y out door satellite. Also EX7500, 7700 nad 8000 working as well in a pinch as extenders with Orbi AC
Aug 23, 2020Guru - Experienced User
How much bigger is the new home?
I would first try the RBK43 in the new home and see how it goes.
30 feet or nore is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
borborygmus
Thank you for the prompt reply. Oh, I'll definitely try my existing kit first. I am just pre-empting this discussion in case.
- FURRYe38Aug 23, 2020Guru - Experienced User
If yoru system is working for you and all your devices and it works in the new home, I would keep it. Unless you don't have any wifi devices that don't support AX, I wouldn't see a real need to scrap what you have and go for something different.
- borborygmusAug 23, 2020Aspirant
OK, but if I need to buy another satellite - which model should I buy? The RBS40 is £200 plus tricky to get. Is there a newer version which is compatible but cheaper? Thanks.
FURRYe38 wrote:If yoru system is working for you and all your devices and it works in the new home, I would keep it. Unless you don't have any wifi devices that don't support AX, I wouldn't see a real need to scrap what you have and go for something different.
