borborygmus
Aug 23, 2020Aspirant
RBK43 Orbi Router and 2 x Satellites, Tri-Band AC2200 - extra satellite required
I have had this sytem for a couple of years now, has worked great in our old house. Now moving to a bigger house and I expect that I may need another satellite - which model should I buy to give me g...
- Aug 23, 2020
You can get a RBS20, RBW30, RBS50, RBS50Y out door satellite. Also EX7500, 7700 nad 8000 working as well in a pinch as extenders with Orbi AC
borborygmus
OK, but if I need to buy another satellite - which model should I buy? The RBS40 is £200 plus tricky to get. Is there a newer version which is compatible but cheaper? Thanks.
FURRYe38 wrote:If yoru system is working for you and all your devices and it works in the new home, I would keep it. Unless you don't have any wifi devices that don't support AX, I wouldn't see a real need to scrap what you have and go for something different.
Aug 23, 2020Guru - Experienced User
- borborygmusAug 26, 2020Aspirant
Thanks for your help. We have now moved in, and the two satellites are not *quite* working as good as I want with coverage. I will be trying some relocations over the next few days.
