Jmb41's avatar
Jmb41
Follower
Jan 11, 2020
Rbk43 satellites have 2.4 ghz connection
My 2 satellites had shown connection type 5ghz then one night my wifi dropped and when it came back up it had daisey chained the satellites. I turned daisey chain off and after a reboot nothing would connect at 5ghz. After a bunch of changing things back and forth I did a factory reset. The satellites are no longer daisey chained but both still connect to the router at 2.4. When I look at devices connected some oc the devices show 5 ghz. My speedtests outside of the app had been 100 to 110 mbps. Now I only hit 70. Any suggestions or ideas?
1 Reply
  • FURRYe38's avatar
    What are your speeds if you turn OFF The RBS and just connect to the RBR?
    Check wired and wireless speeds with the RBR.
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
