Siege7817
Feb 05, 2019Tutor
RBK43 upload speed at 750+ mbps but download capped at 550 mpbs when wired?
Hey everyone,
So my internet is fibre running at 1 Gbps down/750 mbps up and I am using the latest .210 firmware and when I do a speedtest I get 750+ up but only about 550 mbps down. Is there a se...
Feb 05, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
Has a factory reset of the Orbi router and setup from scratch then go in and immediately test speeds with a wired connection? Don't enable QoS, Access Controls or Traffic Meter or IPv6 on the Orbi?
Might review these:
https://community.netgear.com/t5/Orbi/New-RBR50-Satellite-setup-some-thoughts-and-questions/m-p/1695161/highlight/true#M50762
https://community.netgear.com/t5/Orbi/Download-speed-cut-in-half-on-wired-connection/m-p/1695372/highlight/true#M50815
