Siege7817
Feb 05, 2019Tutor
RBK43 upload speed at 750+ mbps but download capped at 550 mpbs when wired?
Hey everyone,
So my internet is fibre running at 1 Gbps down/750 mbps up and I am using the latest .210 firmware and when I do a speedtest I get 750+ up but only about 550 mbps down. Is there a se...
ekhalil
Feb 05, 2019Master
Siege7817 wrote:
Hey everyone,
So my internet is fibre running at 1 Gbps down/750 mbps up and I am using the latest .210 firmware and when I do a speedtest I get 750+ up but only about 550 mbps down. Is there a setting I am missing? This is using wired of course, my wireless speeds are fine. Any suggestions would be great, thanks.
- Do you use wired or wireless backhaul or a combination?
- What other wired devices do you have connected to Orbi?
- Is Daisy Chain enabled or disabled?
- What wireless speeds to do get?
