Siege7817
Feb 05, 2019Tutor
RBK43 upload speed at 750+ mbps but download capped at 550 mpbs when wired?
Hey everyone,
So my internet is fibre running at 1 Gbps down/750 mbps up and I am using the latest .210 firmware and when I do a speedtest I get 750+ up but only about 550 mbps down. Is there a se...
Feb 07, 2019Guru - Experienced User
Any progress on this?
Siege7817 wrote:
Hey everyone,
So my internet is fibre running at 1 Gbps down/750 mbps up and I am using the latest .210 firmware and when I do a speedtest I get 750+ up but only about 550 mbps down. Is there a setting I am missing? This is using wired of course, my wireless speeds are fine. Any suggestions would be great, thanks.
Siege7817
Feb 14, 2019Tutor
Yes when wired, upload is 750+ but download (which is 1 Gbps) is only 550 mbps.
- FURRYe38Feb 14, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
Has a factory reset of the Orbi router and setup from scratch then go in and immediately test speeds with a wired connection? Don't enable QoS, Access Controls or Traffic Meter or IPv6 on the Orbi?
- Siege7817Feb 15, 2019Tutor
Actiontec T3200M, ISP is Telus, ONT is a Nokia. I have no QoS, access controls or Traffic Meter or IPv6 enabled. I will try a factory reset and see if that helps, I tested with my laptop directly to the ISP modem and get 950+ as I should but as soon as I plug the orbi into the same port it maxes out at 550 mpbs but 770+ on upload. So definitely something with the orbi imo.
- FURRYe38Feb 15, 2019Guru - Experienced User
Does Telus use DHCP or PPPoE for the connection from the modem to there services?
