Siege7817
Feb 05, 2019Tutor
RBK43 upload speed at 750+ mbps but download capped at 550 mpbs when wired?
Hey everyone,
So my internet is fibre running at 1 Gbps down/750 mbps up and I am using the latest .210 firmware and when I do a speedtest I get 750+ up but only about 550 mbps down. Is there a se...
alstsmith
Feb 14, 2019Apprentice
Hi there,
This sounds suspiciously like the issue here ORBI used as Gateway Slower than 1GB Connection
Are you connecting with PPPoE on the Orbi?
- FURRYe38Feb 14, 2019Guru - Experienced User
That poster mentioned:
"RBK50 to run at 1GBS via ethernet when setup using PPOE and VLAN201. When I test the speeds with ethernet to the centurylink ZyXEL C3000Z,"
Possible same issue, those he never fully completed giving details or updated about his status. I did refer him to NG support.
Hopefully something you can work with NG support to figure out why PPPoE is not up to speed on this protocol.
alstsmith wrote:
Hi there,
