Siege7817
Feb 05, 2019Tutor
RBK43 upload speed at 750+ mbps but download capped at 550 mpbs when wired?
Hey everyone,
So my internet is fibre running at 1 Gbps down/750 mbps up and I am using the latest .210 firmware and when I do a speedtest I get 750+ up but only about 550 mbps down. Is there a se...
alstsmith
Feb 14, 2019Apprentice
Hi there,
This sounds suspiciously like the issue here ORBI used as Gateway Slower than 1GB Connection
Are you connecting with PPPoE on the Orbi?
Feb 14, 2019Guru - Experienced User
That poster mentioned:
"RBK50 to run at 1GBS via ethernet when setup using PPOE and VLAN201. When I test the speeds with ethernet to the centurylink ZyXEL C3000Z,"
Possible same issue, those he never fully completed giving details or updated about his status. I did refer him to NG support.
Hopefully something you can work with NG support to figure out why PPPoE is not up to speed on this protocol.
alstsmith wrote:
Hi there,
