dja2k
Apr 20, 2020Aspirant
RBK43S-100NAS Signal and Connected Devices
Hi I am new to this forum and had a few questions on my RBK43S-100NAS system I just got at Best Buy. I have it setup already, speed is decent, but the network map shows satelites with poor reception...
- Apr 20, 2020
I would try the new FW. Load the RBS first then RBR lastly, factory reset and setup from scratch. All will be on the same version of FW.
CrimpOn
Apr 20, 2020Guru - Experienced User
Depending on what is "in the path" between router and satellite, 45 ft. may to too far. That said, however, if the satellites glow BLUE for 2 miinutes, that means Orbi thinks the signal is acceptable.
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
