Shunts
Aug 22, 2020Follower
RBK43s saying offline but my internet works on phone and laptops but not on smart tv
My RBk 43s router is offline but satellites are showing in green in app. Also wifi is working on Phones and laptops but not on my smart tv. Please suggest, Thanks in advance
Mstrbig
Aug 23, 2020Master
I have a Vizio TV. It was stubborn and wanted to connect 2.4Ghz even though it was 3 ft from the Orbi router. I ended up having to do a TV soft reset, connect to the guest WIFI, then change to the WIFI before it would lock into 5Ghz. Now it stays on the proper WIFI at 5Ghz, even if I reboot the Orbi or we lose power.
