Ascrept49's avatar
Ascrept49
RBK43S versus RBS50Y
The RBK43S ORBI10 router/mesh satellites, has not provided any better WiFi to my outdoor security cameras.  I currently have WiFi to those cameras, it could be better.  Would I be better off looking at the RBS50Y? and then secondly, if the suggestion for RBS50Y is yes, then would it work with the older Nighthawk X65 AC3000 tri-band R7900P or should I stay with the ORBI10?
1 Reply
  • FURRYe38's avatar
    The RBSY unit is a outdoor satellite.
    How many cameras and devices do you have connected to the Orbi system?
