Ascrept49
Jun 04, 2020Aspirant
RBK43S versus RBS50Y
My ORBI router model number doesn't even show. Question is: since the ORBI RBK43S slightly helped inside and a bit outside of the house, will the RBS50Y help extend my signal to my out buildings and...
CrimpOn
Jun 04, 2020Guru - Experienced User
Can you make a rough drawing of the layout (pencil sketch) and indicate:
- Where the router and satellite are located
- Where the WiFi cameras are located
- The approximate distance to the cameras and "outbuildings".
Ascrept49
Jun 22, 2020Aspirant
I hate the fact that I spent $300 and have not gotten ANY better reception to my wireless cameras (despite the fact that the satellites are now physically closer) than I had with the Nighthawk. Yes, the WiFi reception within our home is a bit better, but that wasn't a problem. I also lost an ethernet export on the main router. How has any of this improved the situation. Answer: it hasn't one iota. In addition, I can't make any direct replies from my emails. The support system here is so insulated from direct communication, it's abysmal.
