House82's avatar
House82
RBK43S vs RBR40 Firmware Update
Quick firmware question:
The firmware for RBK43S (which is a RBR40 router with RBS20 satellites) shows 2.6.2.104, but when I search RBR40 it shows the firmware version to be 2.6.1.36
What is the rule of thumb for updates? Which one do I use? Only reason I ask is that I've been having some intermittent issues with internet the past couple of weeks that weren't present for a long time.
Thanks
  • FURRYe38's avatar
    The later version is most current. Seems that NG didn't update the RBR40 page as these modes are the same models and use same versions of FW. You can update if you wish or keep what works for you. If you have a RBS, update the RBS first, then RBR lastly.
    https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com
    https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satellite
    • House82's avatar
      House82
      Thanks for the response FURRY. Didn't know about updating RBS20's first, as I always did RBR40 and then satellites. Does this have an adverse effect on the update process?
      The intermittent drops just started again a few weeks ago, I'm now seeing about 2-3 drops a day. It was fairly stable for quite some time, even at the latest firmware. Nothing has changed setting wise. This system has been amazing when it works, but for all of the issues it has it's almost to the point of purchasing something else.
      • FURRYe38's avatar
        House82 wrote:
        Thanks for the response FURRY. Didn't know about updating RBS20's first, as I always did RBR40 and then satellites. Does this have an adverse effect on the update process? YES. the RBS can loose connection with the RBR if the RBR is updated first.
        What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
        https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
