ehsiii's avatar
ehsiii
RBK44-100NAS with the xfinity xFi Advanced Gateway Can I disable the XFi wireless router
its a Model Number:  CGM4140COM xfi router can I disable the wireless? Any issues using this with RBK44.?  Thanks
1 Reply
  • CrimpOn's avatar
    CrimpOn
    The way I read it, Xfinity is touted as a "wonderful solution to everything".  They provide a web portal to configure and control the myriad of services: https://www.xfinity.com/support/articles/xfi-app-and-portal Gosh, Xfinity even provides WiFi "extender pods" (sort of like an Orbi system).
    My guess is that by logging into your Xfinity account you can do things like turn off the Xfinity WiFi.
    Have no idea if the Xfinity can be placed into "bridge mode".
    If it cannot, then the easiest solution is to (a) disable the Xfinity WiFi and (b) attach the Orbi in Access Point (AP) mode.
