daveburgandy
Apr 09, 2018Tutor
RBK44 System Unstable
60% of the time it works everytime! With each firmware update I feel like Netgear is getting further and further away from stability. I am so frustrated by this system that I don't know what to do ...
daveburgandy
Apr 10, 2018Tutor
Thank you for your reply. I have not performed a factory reset of the router and salellites. I will try that today and see if that helps.
My home is about 6,000 sqFt and three levels and very wide on the upstairs level. I have a satelite in the basement, the router and a satellite on the main floor and two satellites upstairs. When working properly all satelllites are connected to the router with "Good" 5G connection. I am using the channels the system provided by default - 5G channels for the satellites are 36, 40, 44, and 48. The 2.4G channel set-up is "Auto (10).
Distance from the router to each satellite varies but I would estimate that it ranges from 20 Feet to 50 Feet (I believe with the router and 4 satellites covering 6,000 SqFt the coverage should be excellent). When the system is working I get excellent speeds of 390 MBps to almost 600 MBps on wireless. Faster sometimes if I plus into a satellite. The problem is that the systems drops satellites and drops internet connection. Sometimes it re establishes connection on its own and sometimes I need to reboot. Sometimes one device is connected while another device is not. The Comcast modem (GB service) has been very reliable.
Apr 10, 2018Guru - Experienced User
Bigger than my 5000sqft house with 1 router and 1 satellite.
Yes, please reset the router and ALL satellites and set up from scratch if you have upgraded to v2.1.3.x FW.
I would try this, remove the one satellite thats closest to the router. 20ft is too close to the router. The router has it own range as well and can give coverage on it's down. Satellites should be at least 40 feet to 60 feet in distance from the router depending upon building materials.
Since you have 4 sats running. You might try using only two with the router and see how things go.
Also use a manual channel 1, 6 or 11 on 2.4Ghz. Any unused channels on 5Ghz that your nieghbors might not be using.
What is the Mfr and model of the ISP modem?
You can try disabling MIMO, Daisy Chain and Fast Roaming to test as well after the reset. I have Beamforming enabled on mine and is working well for me.
- daveburgandyApr 10, 2018Tutor
Thanks again! I have completely reset and reinstalled my network after the firmware update. I have turned off daisy chaining (shouldn't need it based upon the location of the Satellites) and enabled beamforming. I hope this does the trick.
Best,
Dave
- FURRYe38Apr 10, 2018Guru - Experienced User
Let us know how it goes.
- daveburgandyApr 17, 2018Tutor
Everything was working great for 72 hours and in the last 48 it has been nothing but trouble again with lots of reboots. Tonight all connected devices were working just fine except for my MBP 15 suddenly lost connection and I could not regain it. I then realized that this device was plugged directly into one of the satellites. I renewd the lease on my computer and it fired right up. It is a faster connection speed when I wire into the satellite so I hate to give up on that option. Any ideas?
