fteng12
Aug 09, 2020Aspirant
RBK50 - Devices not connecting to closest Satellite
I set up a new RBK50 system with 2 included satellites. I also added one RBS20 satellite to the system. In looking at the each Satellite, devices are not connecting to the closet Satellite causing ...
fteng12
Thanks for responding. I tried your suggestion and powered off my laptop and back on. I also choose to forget the network and accessed it via password again and it is still not connecting to the closest satellite.
If there are any other suggestions, I would appreciate it.
Mstrbig
Aug 09, 2020Master
How far apart are you satellites? The recomended distance is 30ft+. Also other things come into play, even though you say they are all abouyt the same distance apart. Interference, walls, etc can make one satellite stronger than the other. The RBS50s are stronger than the RBS20. You may want to move that one further away, since the RBR50s also have a faster wireless backhaul.
The only other thing I would do, if nothing else helped, is start from scratch and reset the Orbi router and satellites. Then configure the router and follow 1 by one with each satellite, moving them to their desired location, before setting up the next satellite.
- fteng12Aug 10, 2020Aspirant
So that is another issue. On the Orbi app, the network map shows that the router is connecting to Satellite 1 (RBS50). Then Satellite 2 (RBS50) and Satellite 3 (RBS20) are connecting via Satellite 1. Satellite 1 has a green dot indicator light showing a "strong" connection. But the other two satellites are showing yellow indicator dots, showing only a "good" connection. But the other two satellites are actually closer to the main router. So I'm not sure why they are choosing to connect via the Satellite that is physically further away except that it seems to have the strongest connection. There are no walls in between any of them. Satellite 2 is on the other side of a small bookcase, so technically not direct line of sight, but not completely blocked.
I tried moving the other two routers further away, but that didn't change anything. I'll try playing with the distance some more.
I saw another article that said to turn off Daisychain or turn on MIMO, etc. Should I try that, or is a reset the best course? I see that you responded to my other issue about the third mystery network "Orbi50", so maybe a reset will solve both problems.
- CrimpOnAug 10, 2020Guru - Experienced UserTurning off Daisy Chain will force all satellites to connect directly to the router.
- MstrbigAug 10, 2020Master
fteng12 wrote:So that is another issue. On the Orbi app, the network map shows that the router is connecting to Satellite 1 (RBS50). Then Satellite 2 (RBS50) and Satellite 3 (RBS20) are connecting via Satellite 1. Satellite 1 has a green dot indicator light showing a "strong" connection. But the other two satellites are showing yellow indicator dots, showing only a "good" connection. But the other two satellites are actually closer to the main router. So I'm not sure why they are choosing to connect via the Satellite that is physically further away except that it seems to have the strongest connection. There are no walls in between any of them. Satellite 2 is on the other side of a small bookcase, so technically not direct line of sight, but not completely blocked.
Try turning off Satellite 1 temporarily and see if the other 2 satellites connect to the RBR50 router. I just installed a system and had a similar problem where satellites were jumping across other satellites to get to the router. They were in a straight line in an office (router - satellite - satellite - satellite). I ended up having to let each satellite settle in a bit, by waiting 15 minutes or so before turning on the next satellite. Once I did that, having daisy chaining on because of all wireless backhaul, they all connected the way I wanted, (router to sat 1 to sat 2 to sat 3.
