ChuckieCheese
Nov 11, 2017Luminary
RBK50 - does the satellite have different password than the router?
I have the RBK50 for a long time and have changed the router password during the initial setup. I also set firmware update to "Auto". Today, after logging-in to the router (say 192.168.0.1), I no...
st_shaw
Nov 11, 2017Master
The satellite password is the same as the router. Try again. If it still doesn't work, you could try to reset the satellite and add it again from the router.
gjs28
Nov 13, 2017Tutor
This worked for me. I reset the satellites (holding the reset pin while power is connected), added them back to the network, and the passwords now match, so I was able to manually upgrade the FW.
