zmon
Jul 24, 2021Guide
RBK50 - Downloading large files slowing down entire network - QoS/SQM?
Hey all, I've got an RBK50 system that I've been noticing will slow down my entire network when one computer is downloading a large file/game/whatever. I recently moved from cable (50/5) to fiber...
moonie-man
Sep 15, 2021Aspirant
I've also been having this issue lately, to the point where I cannot download anything larger than about 250MB, or else my remote connections to the office all die off and I have to wait for the download to finish (or not start it to begin with -- not practical!) before I can log back into my work computer. I have the RBR750, and I found through different posts on this forum that http://orbilogin.net/QOS_main.htm will allow me to "change" the QoS settings.
I put "change" in quotations, because no matter how I try to set QoS on this router, I either get "Invalid uplink bandwidth" or I get to login and try all over again. Or perhaps something different happens and I get taken to a speed test page, where all I can do is test the bandwidth, and there is no mechanism to get back to the main page with the info collected from the test.
So I have to start all over again, and get the same "error" and get the same dumb process. I am searching for a better mesh router, because clearly Netgear is not ready for prime time when it comes to providing a robust product that does the job I expect it to do.
Sep 15, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
