J-L-B
Apr 03, 2020Aspirant
RBK50 - No internet conneciton
I purchased an ORBI RBK50 and trying to connect it to the internet. RBK50 is used as a router and it connects to a modem (NCD). I managed to connect to the ORBI router with the App and the App is...
J-L-B
Not sure how to check or update the firmware because I cannot see the ORBI settings on the gui or App.
Can firmware be updated without gui or App?
Retired_Member
Apr 03, 2020
Do you have a pc ? Better to login there
- J-L-BApr 03, 2020AspirantYes have a laptop.
Do I connect to the ORBI via 192.168.1.1 when laptop is connected vi WIFI? If yes, I tried that and ORBI still tries to establish an internet connection forst without giving me any of the setting options on the ORBI.- Retired_MemberApr 03, 2020
Ok. Have you told us what type of modem you have?
- J-L-BApr 03, 2020AspirantNetcomm FTTC device model NDD-0300
