J-L-B
Apr 03, 2020Aspirant
RBK50 - No internet conneciton
I purchased an ORBI RBK50 and trying to connect it to the internet. RBK50 is used as a router and it connects to a modem (NCD). I managed to connect to the ORBI router with the App and the App is...
TUSON1
May 21, 2020Aspirant
Hi
when i purchased this Orbi RBK50 i was told i dont need a modem. is this correct. i have been using a Nighthawk upto now which had a built in modem.
thans
i
J-L-B wrote:I purchased an ORBI RBK50 and trying to connect it to the internet. RBK50 is used as a router and it connects to a modem (NCD).
I managed to connect to the ORBI router with the App and the App is assiting in setting up the ORBI system.
Im getting an error: Cannot establish an internet conneciton:
My ISP uses DHCP (not static IP or PPPoE). App asked me for previous router MAC which also didnt work.
I've reset both ORBI and NCD to start from scratch but no luck.
Plus I cannot get into the ORBI settings via the APP or GUI to see what the settings are in case I need to change anything because it looks like the ORBI wants an internet connection first.
Any helpers?
Regards.
- FURRYe38May 21, 2020Guru - Experienced User
You can use the Orbi system with out a modem if you just want internal LAN side operations. However if you wanting internet services, a modem or ONT IS required for the Orbi system to work in that capacity.
TUSON1 wrote:Hi
