pomkon's avatar
pomkon
Follower
Apr 06, 2020
RBK50 - RBR50 wont work with RBS50
First time using RBK50. I followed and completed the setup. Whenever I turn on the satellite, it tries to connect to the router, then the whole system loses connection. If just the router on its own, eveything is fine.
Firmware updated.
1 Reply
  • FURRYe38's avatar
    Is the RBS wireless or wired to the RBR?
    Try a factory reset on the RBR and RBS and setup from scratch.
    https://www.youtube.com/watch?v=cMw4ePACgc4
    https://www.howtogeek.com/434350/how-to-factory-reset-a-router/
    Have the RBS in the same room as the RBR. Walk thru the setup wizard, skip adding it during the wizard process. Don't enable Circle or Armor. Disable Daisy Chain on the RBR Under Advanced Tab/Advanced Settings/Wireless Settings. Once you complete the setup, press the sync button on the RBR then on the RBS. The RBS should sync. Use a wired PC or laptop to connect to the RBRs web page at 192.168.1.1 and check the status of the RBS connection.
    What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
    Daisy Chain, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
