anthony17's avatar
anthony17
Follower
Mar 07, 2018
RBK50 - Router Light Ring Pulses White And Internet Drops
Hi everyone, for the past few months I have been having issues with my RBK50. For some reason, the light ring pulses white for about a minute and the internet drops and then restores like nothing happened. I am not sure what is causing this and I woul appreciate any help anyone can give me. The problem only lasts for about a minute. I am running firmware version 2.1.2.18. Has anyone else had similar issues with this model?
  • Retired_Member's avatar
    Retired_Member
    .18 has reported problems
    you may want to fall back to .14
    Call Netgear support
  • FURRYe38's avatar
    What is the Mfr and model of the ISP modem? Buillt in router by chance?
    As VAJim suggested, you might revert back to v2.0.1.4. Use IE11 or FF browser to send the file. Factory reset both Router and Satellites. Set up the Orbi router first.
    Set Manual channel to 1, 6 or 11
    Set WPA2 and AES only.
    Disable 20/40Mhz Coexistence
    Disable Beamforming and MIMO, Daisy chaing and Fast Roaming if any of these are available after downgrading.
    • RGT3's avatar
      RGT3
      I am having the exact same problem.
      • FURRYe38's avatar
        What version of FW are you using? If v.18 then you might want to revert back to v2.0.1.4.
