fteng12
Aug 09, 2020Aspirant
RBK50 - Router sending out add'l wifi network
I set up a new RBK50 system with a router and two satellites. During set up, I changed the network name to a personal name and also enabled the Guest network afterwards. Everything with that wifi n...
CrimpOn
Aug 09, 2020Guru - Experienced User
fteng12 wrote:I noticed on my computer that there is an add'l wifi network available called "Orbi50". I was curious and tried to connect and I was able to.
My, my, my. Before recommending a "Factory Reset" and start over, do you have any WiFi tools? For example, on Windows there is WifiInfoView (free). Android has various WiFi Analyzer apps. Any of these will display the SSID of all available WiFi networks and also the MAC address of each access point (including the "hidden" router access point for the 5G WiFi backhaul). There are a dozen other WiFi Scanner programs. I just happen to use these two.
The primary and guest SSID's on each of your Orbi devices should each have the same WiFi MAC address for 2.4G and for 5G. This makes three primary MAC's and three guest MAC's on both 2.4G and 5G. If the MAC address on this ORBI50 matches any of those MAC addresses, "Houston, we have a problem."
- BIG9MMAug 09, 2020Apprentice
Android and Apple IOS apps for Wifi analyzer
- MstrbigAug 09, 2020Master
The reset button on the back of the Orbi acts 2 ways. Long press will factory reset. Short press will reboot the router or satellite. As mentioned a short press on the reset button may clear he eronious WIFI name. At first I thought maybe you named the main WIFI but forgot to name the Guest WIFI. But I see you are showing 3 networks to log into, your 2 named networks and Orbi50
- fteng12Aug 09, 2020Aspirant
Thanks for the info on the reset. Yes, I'm seeing 3 networks, the main one, a guest one and the "Orbi50" network.
Oops, didn't see this iOS option you posted. I'll look into it. Thanks.
- BIG9MMAug 09, 2020ApprenticeAll good đ
I'm on a Mac, so can't use those programs. I'll see if I can find some other way to look that info up. Thanks.
