fteng12
Aug 09, 2020Aspirant
RBK50 - Router sending out add'l wifi network
I set up a new RBK50 system with a router and two satellites. During set up, I changed the network name to a personal name and also enabled the Guest network afterwards. Everything with that wifi n...
BIG9MM
Aug 09, 2020Apprentice
Android and Apple IOS apps for Wifi analyzer
Mstrbig
Aug 09, 2020Master
The reset button on the back of the Orbi acts 2 ways. Long press will factory reset. Short press will reboot the router or satellite. As mentioned a short press on the reset button may clear he eronious WIFI name. At first I thought maybe you named the main WIFI but forgot to name the Guest WIFI. But I see you are showing 3 networks to log into, your 2 named networks and Orbi50
- fteng12Aug 09, 2020Aspirant
Thanks for the info on the reset. Yes, I'm seeing 3 networks, the main one, a guest one and the "Orbi50" network.
