th3sp3ck
Aug 13, 2020Guide
RBK50 -> Satellite RBS50 - Won't work and wont reset?
I have a RBK50 system I bought in April of 2018. Earlier this week I started getting certificate and authentication errors. With the help from this community (thank you!) I was able to triage to f...
Aug 13, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. Once it's connected and synced. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
th3sp3ck wrote:I have a RBK50 system I bought in April of 2018. Earlier this week I started getting certificate and authentication errors. With the help from this community (thank you!) I was able to triage to figure out that it was only devices connected to the Satelitte (RBS50) giving me these errors and the base unit (RBR50) works just fine. If I unplug the satellite, anything connected to the base unit works just fine (assuming its in range).
Now for the life of me, I can not get the satelitte to reset to factory settings. I've tried numerous times in a dozen different ways. I've unplugged, used the pin in the back, removed it from the network map, the app, sync button, etc. The satelitte just pulsates white and if it does reconnect to the router, I just get the same authentication/certificate errors when a devices connect to it.
Anyone have any suggestions? Its extremely disspointing that this expensive system that I previously loved and have recommended to others, is now giving me such fits.
