Caplaur
Sep 15, 2020Aspirant
RBK50 - Slow speed on older devices
Hi everybody, I have a new Orbi system (RBK50), router + 1 satellite. My home has about 2000sq ft (total on 3 levels, basement + 2 stories). Router is in basement, satellite is on 1st floor at 28...
Mstrbig
Sep 15, 2020Master
Speed on the older items may be due to the limitations of their wireless card.
Try these settings on the Orbi
orbilogin.com
Advanced > Advanced Setup > Wireless Settings
Disable Circle, Armor, Daisy Chaining, Fast Roaming, IPv6 and uncheck 20/40Mhz Coexistence.
Enable WMM, Implicit BeamForming, Mu-MIMO
Set Short preamble mode. Save settings, reboot Orbi.
Since you've done some of these already, do the ones you haven't.
Caplaur
Sep 16, 2020Aspirant
Mstrbig wrote:Speed on the older items may be due to the limitations of their wireless card.
orbilogin.com
Thank you for your fast reply, I tried all these and still no changes.
I also manually reflashed router firmware (as suggested by Netgear tech support), reset to factory defaults, still same speed as before.
- MstrbigSep 16, 2020Master
Try forgetting the WIFI on each device, reset the network on each device by following the device's instructions on how to perform this. go into each device's WIFI settings and make sure they are set for optimum performance.
For instance:
Reset Network Settings - Samsung Galaxy Tab S
From the Home screen, navigate: Apps icon > Settings > Backup and reset.
Tap Reset network settings.
Tap RESET SETTINGS.
If applicable, enter the PIN, password, fingerprint or pattern then tap RESET SETTINGS again to confirm.- CaplaurSep 16, 2020Aspirant
Mstrbig wrote:Try forgetting the WIFI on each device, reset the network on each device by following the device's instructions on how to perform this. go into each device's WIFI settings and make sure they are set for optimum performance.
For instance:
Tap RESET SETTINGS.
If applicable, enter the PIN, password, fingerprint or pattern then tap RESET SETTINGS again to confirm.Thans again !
Tried this, still no luck.
Maybe a firmware issue ?
