AmanSingh
Feb 06, 2020Tutor
RBK50 - Slow Wifi Upload speed
Hello, I got New Orbi mesh system in September 2019, it had an issue with Slow wifi upload speeds since day 1. After months of hassle with support i was issued a new Orbi system. The bew Orbi syste...
AmanSingh
Feb 06, 2020Tutor
Thanks for your response FURRYe38 below are the details:
What Firmware is currently loaded? 2.5.1.8
What is the Mfr and model# of the ISP modem the NG router is connected too? RicherLink Epon ONU Model RL801E
Is the Orbi system operating in Router or AP mode? Router Mode
What is the size of your home? Sq Ft? 2400 sq ft (2 floors, 1200 each)
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router - Currently i do not have the satellite connected. Am only using the router as of now
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. Auto is currently set. Tried changing to different channels, still doesnt works
Any Wifi Neighbors near by? If so, how many? Yes, 7
Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings: Tried multiple combinations disabling those, still the same result.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Tried multiple combinations does not resolves. When Daisy chain is disabled , the download speed also goes down.
Feb 06, 2020Guru - Experienced User
Try a Facory reset the RBR and setup from scratch...
What devices are you using to check speed?
- AmanSinghFeb 06, 2020Tutor
Hello FURRYe38
Factory reset works, but after a few days, it goes back to the same situation.
It is strange only the upload speed over the wifi gets affected and it comes down to 1/4th of the speed that it should connect with.
I have checked the speeds with below devices:
1. Windows Laptop over Wifi
2. iPhone
3. Samsung Phone
4. Desktop - Speed is fine over wired connection
Regards
Aman
- FURRYe38Feb 06, 2020Guru - Experienced User
I would contact NG support and ask for additional help and information regarding this. Possible your system maybe faulty.
