AmanSingh
Feb 06, 2020Tutor
RBK50 - Slow Wifi Upload speed
Hello, I got New Orbi mesh system in September 2019, it had an issue with Slow wifi upload speeds since day 1. After months of hassle with support i was issued a new Orbi system. The bew Orbi syste...
Alienr0x
May 24, 2020Aspirant
I have exacly the same problem, did you solved It ?
- AmanSinghMay 24, 2020TutorHello,
The issue still exists. Am learning to live with it since NG support is not good in India to replace the full system twice nor refund it.
I am using a different wifi system in the same environment and have no issues with that which also rules out the environment concern raised by Furry in his above comment.
If you have a return policy, i would suggest return it if NG doesnt fix your issue.
If they do fix, do let me know the resolution you got.
Regards
Aman- Alienr0xMay 24, 2020AspirantUnlucky my orbi is no more in warranty and im with FTTH from just some days, before i was with low upload from fttc so i was not able to see this problem, ill try anyway to contact Netgear. Thank you
- AmanSinghMay 24, 2020TutorIf you reset your orbi, it temporarily fixes the upload issue. It will lower the speed again if the system reboots
- FURRYe38May 26, 2020Guru - Experienced User
You can try Voxels FW for Orbi:
https://community.netgear.com/t5/Orbi/Voxels-FW-available-for-50-series-Orbi-only-available/m-p/1883615#
You can revert back to stock FW if it doesn't work out for you.
AmanSingh wrote:
Hello,
Regards
Aman
Is the Orbi system operating in Router or AP mode?What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless SettingsTry disabling the following and see:
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).Has a factory reset and setup from scratch been performed since last FW update?
Alienr0x wrote:
I have exacly the same problem, did you solved It ?- GerryGoaJun 25, 2020Aspirant
I have the same issue, slow wifi speed. I have 1GB, I get anywhere between 2mbps to 150 mbps on wifi on several devices.
. I'm going to return it back, I wasted enough time on this BS.
Factory resetting, rebooting, crap support, such a waste of my time.- FURRYe38Jun 25, 2020Guru - Experienced User
You'll not see any wifi speeds near 900Mpbs with Orbi AC. WIred yes you should.
Seems like a bit more trouble shooting and suggestions to help you narrow down the problem would be needed. You didn't even give some of us here in the forums a chance to help you out so, I don't think you can accuse us of bad support.
Other including myself have good performances with Orbi AC systems.
Good luck.
GerryGoa wrote:I have the same issue, slow wifi speed. I have 1GB, I get anywhere between 2mbps to 150 mbps on wifi on several devices.
