AmanSingh
Feb 06, 2020Tutor
RBK50 - Slow Wifi Upload speed
Hello, I got New Orbi mesh system in September 2019, it had an issue with Slow wifi upload speeds since day 1. After months of hassle with support i was issued a new Orbi system. The bew Orbi syste...
Alienr0x
May 24, 2020Aspirant
I have exacly the same problem, did you solved It ?
AmanSingh
May 24, 2020Tutor
Hello,
The issue still exists. Am learning to live with it since NG support is not good in India to replace the full system twice nor refund it.
I am using a different wifi system in the same environment and have no issues with that which also rules out the environment concern raised by Furry in his above comment.
If you have a return policy, i would suggest return it if NG doesnt fix your issue.
If they do fix, do let me know the resolution you got.
Regards
Aman
Regards
Aman
- Alienr0xMay 24, 2020AspirantUnlucky my orbi is no more in warranty and im with FTTH from just some days, before i was with low upload from fttc so i was not able to see this problem, ill try anyway to contact Netgear. Thank you
- FURRYe38May 26, 2020Guru - Experienced User
You can try Voxels FW for Orbi:
https://community.netgear.com/t5/Orbi/Voxels-FW-available-for-50-series-Orbi-only-available/m-p/1883615#
You can revert back to stock FW if it doesn't work out for you.
AmanSingh wrote:
Hello,
Regards
Aman
