AmanSingh
Feb 06, 2020Tutor
RBK50 - Slow Wifi Upload speed
Hello, I got New Orbi mesh system in September 2019, it had an issue with Slow wifi upload speeds since day 1. After months of hassle with support i was issued a new Orbi system. The bew Orbi syste...
Alienr0x
May 24, 2020Aspirant
I have exacly the same problem, did you solved It ?
May 26, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
- GerryGoaJun 24, 2020Aspirant
I have the same issue, slow wifi speed. I have 1GB, I get anywhere between 2mbps to 150 mbps on wifi on several devices.
. I'm going to return it back, I wasted enough time on this BS.
Factory resetting, rebooting, crap support, such a waste of my time.- FURRYe38Jun 25, 2020Guru - Experienced User
You'll not see any wifi speeds near 900Mpbs with Orbi AC. WIred yes you should.
Seems like a bit more trouble shooting and suggestions to help you narrow down the problem would be needed. You didn't even give some of us here in the forums a chance to help you out so, I don't think you can accuse us of bad support.
Other including myself have good performances with Orbi AC systems.
Good luck.
GerryGoa wrote:I have the same issue, slow wifi speed. I have 1GB, I get anywhere between 2mbps to 150 mbps on wifi on several devices.
Factory resetting, rebooting, crap support, such a waste of my time.- AmanSinghJun 25, 2020TutorI actually side with Gerry here. If few systems are working fine and a lot of users are facing issues similar to myself, that doesnt means Netgear shouldnt acknowledge it as “there is no issue” They should have their top of the line dev to work on the firmware and software side of the mesh system. People are heavily investing in these systems. This post already shares the history of users facing similar issues and tshooting already providing. Factory resetting the system after ever few days is not a solution it is a workaround and a painful one.
