AmanSingh
Feb 06, 2020Tutor
RBK50 - Slow Wifi Upload speed
Hello, I got New Orbi mesh system in September 2019, it had an issue with Slow wifi upload speeds since day 1. After months of hassle with support i was issued a new Orbi system. The bew Orbi syste...
Jun 25, 2020Guru - Experienced User
I agree to a point however still, due diligence in troubleshooting to narrow down where the actual problem is needs to be done. One just can't blame NG entirely. There are many factors and conditions that can cause problems for ANY wifi system. Users here in the forums are here to help in this area to see if the problem can be found and resolved first. Then if not then NG support needs and should be involved. I and others here in the forums have helped resolved many issues for users problems. Tells me that not all of the problems can be heaped on NG.
AmanSingh
Jun 25, 2020Tutor
NG support not acknowledging the problem tells a different story. A bug is not always causing issues to everyone but it does hits a lot of consumers. By now we should already have a bug id generated for it. But guess what it hasn’t. We did worked with NG support to get it resolved, they simply waited for weeks before gathering info and never responded unless you followup, thats not how a good support works. Moreover, the replacement policy is not the same in every region. We dont even get the option for returning or replacing it with a new orbi system. Even after NG support gave up. I can show you 50 tickets assigned to my account for the same issue. Which still persists.
- AmanSinghJun 25, 2020TutorI do have a google mesh system from my friend just to verify if it is not an environment issue. And guess what it is not. Google wifi worked fine for me for several weeks without these issues. So yes i will blame NG and have the right to do so publicly since am not getting the service on the product that i purchases.
- FURRYe38Jun 25, 2020Guru - Experienced User
Sorry about your experiences. This again will be something that NG support needs to continue to help you with. RMA or ask about a refund if you bought the system from them. Contact a forum moderator and have them try to help you out as well.
- GerryGoaJun 25, 2020Aspirant
Hi,
Sorry if I seemed harsh, but i'm really frustrated. This forum is great and tried all the suggestions posted here, but nothing worked. This mesh system is not cheap and if I paid 100$ I would probably keep it and not even bother. But I paid 500$.
The only possible issue now is probably the Fibre optic cable not tapped correctly (from what I read in the forum).
I will try with some other mesh network perhaps if possible.
After trying all the suggestions here, I tried calling support, but no one picks up, not sure if it's 24x7 support as I called at 3am. I can't do it during the day cos with Covid we're all working from home and I can't test it during the day.
Just inquisitive , what's a good range for different devices, laptop, cell phone and tablet, all through wifi. Wired connection is fine.
On my phone, I get anywhere in the range of 5mbps to 150mbps, wierdly the closer I am to the router, slower the speed. Also on WifiAnalytics app I am getting 25mbps, and through teh Orbi app I'm getting 135mbps
Let start with questions, yes you may have done them however for us, we don't know what you did exactly.
What ISP Speeds UP and Down do you pay for?What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-SpeedDistance will vary and as connection rates. You can always have an expected max connection rate with the RBR or RBS if your device is at a distance along with building materials will also play a role in this as well. If wired connections are good then there may just a wireless issues that needs to be figured out.
What WiFi devices do you have?
GerryGoa wrote:Hi,
- GerryGoaJun 26, 2020Aspirant
Hi FURRYe38,
I posted my wifi details in a new post, any help would be appreciated. Didn't want to hijack Aman's post.
https://community.netgear.com/t5/Orbi/Orbi-RBK50-Speed-Problems/m-p/1936594#M96265Thanks in advance,
Gerry
- FURRYe38Jun 26, 2020Guru - Experienced User
Seems the post didn't make it or something happend. Please repost again and we'll help you figure this out with you.
GerryGoa wrote:Hi FURRYe38,
Gerry
Here it is again, the link works, I tried it, not sure why you can't see it.
But here it is again.
I seem to be getting slow wireless Internet connection speed, wired is fine. Cell phones still seem very slow. I only managed to get high speed the first day or 2, don't remember exactly how much, but I was satisfied, not any more.
I have a 3400 sq. ft home, 3 levels. Bell Home Hub 3000 router is in the basement. Construction is pretty standard, more open concept and walls are drywall. I have cat5e cabling from the basement to the office and family room on 1st level and another cable running up to the landing area on the 2nd level.
My old system includes 2 TP-Link Archer C7 access points. But wifi sucks lately (<5mbps sometimes) in the last 6 months or so.
Got the Orbi RBK50 for better wifi and mainly faster internet speed.
I connected the Orbi RBK Router to the Office on 1st level. The Satelite to the landing area. It will be about 30 feet apart or less. I have also tried connecting the Router to the Family room with similar speed. All speed tests were run with ookla.Settings info:
Firmware V2.5.1.16
WMM enabled for 2.4(Auto) & 5 Ghz(Ch:48)
Enable Daisy-Chain Topology
Enable Beamforming
Enable MU-MIMIO
Disabled Fast Roaming
Disabled IPv6
Router Mode
Disabled Armor
Disabled 20/40 MHz Coexistence
All speed tests were done late night with no other devices connected.These are the speeds I get (download / upload), I used a laptop.
Bell Home Hub 3000 Router - 1.13 gbps / 824 mbps
TP-Link Archer C7 Router - 812 / 806
Wired directly to Bell router - 843 / 816
Wired to Orbi RBK50 - 725 /735
Orbi App on cell phone - 545 / 813
Wireless connected to Orbi Router(2 feet from router) - 256 / 257
Wireless through Huawei phone(2 feet from router) - 45 / 34Living Room - 10-20ft from router -
Laptop - 240 / 267
Cell phone - 47 / 8Family Room - 25-35ft in between router and satellite
Laptop - 181 / 166
Cell phone - 36 / 14Kitchen - 35-45ft between router and satellite
Laptop - 200 / 158
Cell - 7 / 5mbps2nd level
Landing aread - 3 ft away from satellite
Laptop - 217 / 252
Cell - 42 / 32Bedroom 1 - 25 ft away from satellite
Laptop - 213 / 257
Cell - 38 / 13Bedroom 2 - 40 ft away from satellite
Laptop - 230 / 357
Cell - 17 / 8 - rgtgeorgeNov 21, 2020Aspirant
I have the same problem. I have a RBK50 with one satellite. The Wifi Speed is 30% of the actual speed. The direct wired connection speed is fine. I tried all setting changes that were recommended. The problem is not solved. Seems to be a model problem and many are living with the issue. Really bad performance.
- FURRYe38Nov 21, 2020Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satelliteWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless SettingsTry disabling the following and see:
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
rgtgeorge wrote:I have the same problem. I have a RBK50 with one satellite. The Wifi Speed is 30% of the actual speed. The direct wired connection speed is fine. I tried all setting changes that were recommended. The problem is not solved. Seems to be a model problem and many are living with the issue. Really bad performance.
- FURRYe38Dec 01, 2020Guru - Experienced User
Any progress on this?
