Healthcare's avatar
Healthcare
RBK50 - Syncing/Adding Satellite Does Not Work
I've had an orbi RBK50 and satellite set up for about 6 months (firmware: V2.2.1.210) with minimal issues but two days ago found that the satellite had lost connection (turned magenta). I tried some ...
  • FURRYe38's avatar
    Ok, I would make contact with NG support and see what options you have avialable. Might ask about and RMA if thats available. Seems like the satellite is bad.:smileysad:
    Blanca_O
    Healthcare wrote:
    I moved the router and satellite into the same room to troubleshoot, so it shouldn't have any issues with that.
    I can select the SSID for the satellite but it doesn't connect, it just sits there trying with no success. It's like it's broadcasting but not the right stuff.
