shobuddy's avatar
shobuddy
RBK50 - two firmware versions?
Why are there two firmware versions for the RBK50 and which one should be used? Edit: screenshot doesn't seem to be working but the versions are 2.7.1.104 and 2.6.1.40.
  • CrimpOn's avatar
    Feb 28, 2021
    Yes, two versions, and no explanation why.  Isn't it a hoot!
    There is an urban legend that the 2.6 firmware might be intended (a) for world wide rather than US, or (b) for customers who prefer to remain with Disney Circle rather than migrate to the new Netgear Patental Controls. At one point, one of the versrions was labelled "U.S. Only", but that comment has disappeared.  Netgear provides NO EXPLANATION.
    So, what are customers supposed to do?
    • One school of thought is, "if it ain't broke, don't fix it."  We see posts every day that start off with, "updated Orbi firmware and now....(something horrible happened)."  All these "security fixes" seem focussed on the LAN side of the Orbi, not on security breaches from the Internet.
    • Another school of thought is, "If a security fix is serious, Netgear will push new firmware."  During the origiinal setup, users have to click "ok" to the statement, "i realize that Netgear may push firmware updates to my system."  Then let Netgear do what they said they'd do.
    • There are some of us who think, "what the heck, it new firmware does something bad, I will just reinstall the firmware I had before." No Biggie.  I am on 2.7.2.104. Had some hiccups and did a factory reset. Now all good.
    You wanted answers. Sorry.
    p.s. images posted "in-line" using the Photo icon do not appear until a forum moderator approves them, which can take hours. Images attached with the "Browse" button appear immediately.
