Ha_Ku_Na
May 31, 2018Luminary
RBK50 / 3x RBS50 -> download slowed down since a few days, upload not affected
Hi
I experience an issue with the download performance since a few days.
My system:
1x RBK50 connected to provider router (router mode, I know doublöe NAT, but I want to ise the DNS of the OR...
- Jun 06, 2018
Hi
I installed the new fw in the meantime and made further testing.
The issue seems to be either isp or router (from isp) related.
I tested with a wired laptop directly on the isp router and experienced the same effects.
The provider will no deliver a replacement router. Therefore I guess I can close this issue.
thx for some helpul hints.
DarrenM
Jun 06, 2018Sr. NETGEAR Moderator
Hello Ha ku Na
You may want to try the latest firmware see if it helps with the speed issue you are seeing.
https://community.netgear.com/t5/Orbi/Orbi-firmware-update-v2-1-4-16-availability/m-p/1585613#M32993
DarrenM
Ha_Ku_Na
Jun 06, 2018Luminary
Hi
