Keanwo
Feb 07, 2022Follower
RBK50 5ghz Speed Lower Than Expected
Hi, I've just set up my RBK50 (2 pack) system and the speeds don't seem to be adequate on the 5ghz channel. In the advanced settings I can see that the 5ghz channel says up to 866.7 Mbps, but am ...
- Feb 08, 2022
I hope that this helps - I found a website that explains "what to expect" from various devices when connected to a gigabit connection.
Go to https://support.google.com/fiber/answer/6250056#zippy=%2Cmobile-devices-wi-fi and expand the three (3) sections:
1) Mobile devices (Wi-Fi)
2) Computers (Wi-Fi)
3) Computers (Ethernet or USB adapter to Ethernet)
I understand that the website is for Google Fiber, but the information it provides is useful regardless of ISP.
Specifically under the "MOBILE DEVICES (Wi-Fi)" section you will see that the most that you will get from a mobile device using 802.11ac is around 390Mbps. So what you are describing is your Orbi providing the speed it is designed to provide. Hope that this helps set expectations.
krlesch
Feb 08, 2022Star
Feb 08, 2022Guru - Experienced User
Nice and all however it doesn't include references to 2x2 and 4x4 antenna support factor which IF a devices as 4x4 antennas, it's it very possible to get near 900mpbs or over on WiFi6 AX mode. Also it's possible to see near 900Mpbs on 5Ghz AC if 160Mhz channel with is supported on some devices. https://www.duckware.com/tech/wifi-in-the-us.html
- krleschFeb 10, 2022Star
Well since the OP has a RBK50 discussing WiFi6 AX mode and the use of 160Mhz channel is moot - wouldn't you agree?
