snoopy77
Nov 21, 2020Aspirant
RBK50 AC3000 Ethernet and wireless
Can you have one Satelite connected via Ethernet back to the Router and the other Satelites working on wireless ? , if so do you need to change any settings on the devices or will it just work?
Nov 21, 2020Guru - Experienced User
Yes you can do that and no you don't need to change any settings. I haven't needed to change any settings and I routinely do this.
snoopy77
I'll assume that the Satelite will then talk back to the other Satelite or the Router depending on which one is closest?
