snoopy77
Nov 21, 2020Aspirant
RBK50 AC3000 Ethernet and wireless
Can you have one Satelite connected via Ethernet back to the Router and the other Satelites working on wireless ? , if so do you need to change any settings on the devices or will it just work?
Nov 25, 2020Guru - Experienced User
Once RBS are wirelessly connected, just connect the ethernet cable in between the RBR and RBS.
