TP067
Feb 07, 2022Aspirant
RBK50 and Altice (Suddenlink)
I have read through many helpful posts in this community and know what I need to do, but can't... so my question is what happens... My ISP (Suddenlink) replaced my old Arris modem with their all ...
- Feb 10, 2022
Hello TP067,
The ISP WIFI does not have to be turned off for AP mode on the Orbi to work.
Please try the solution and keep me updated with the progress on this issue!
Best,
Kevin
Community Team
CrimpOn
Feb 07, 2022Guru - Experienced User
What is the specific model number of the Altice device?
Do you have access to any settings on the Altice?
(can you set the channels? set power levels? assign the WiFi SSID?)
The tech support may be correct. There is no method to 'turn off' WiFi on the Netgear Orbi products.
TP067
There is no model number on it.
I have no access to it whatsoever - they have us completely locked out, cannot change the SSID or anything!
What I wonder is if I put the orbi in AP mode, without turning wifi off on the Altce, would that solve the problem?
- CrimpOnFeb 07, 2022Guru - Experienced User
TP067 wrote:
What I wonder is if I put the orbi in AP mode, without turning wifi off on the Altice, would that solve the problem?
I do not see how the Orbi 'mode' should have anything to do with this issue.
For certain, you want the Orbi WiFi SSID to be different from the Altice WiFi SSID and you want the WiFi channels to be different, especially the 2.4G channel.
