TP067
Feb 07, 2022Aspirant
RBK50 and Altice (Suddenlink)
I have read through many helpful posts in this community and know what I need to do, but can't... so my question is what happens... My ISP (Suddenlink) replaced my old Arris modem with their all ...
- Feb 10, 2022
Hello TP067,
The ISP WIFI does not have to be turned off for AP mode on the Orbi to work.
Please try the solution and keep me updated with the progress on this issue!
Best,
Kevin
Community Team
KevinLiT
Feb 09, 2022NETGEAR Moderator
Hello TP067,
I understand you are having issues with wireless internet connectivity with your Orbi router. Please consider putting the Orbi in AP mode.
Follow the link below to configure Orbi router as an access point:
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
Please keep me updated on the progress on the situation.
I look forward to hearing from you!
Best,
Kevin
Community Team
TP067
Feb 09, 2022Aspirant
Thank you, Kevin!
This is what I want to do, but back to my original question... does the wifi have to be turned off on the ISP modem/router combo for Orbi to work in AP mode?
If not, then yes, this will solve my issue!
- KevinLiTFeb 10, 2022NETGEAR Moderator
Hello TP067,
Best,
Kevin
Community Team
