SazzaF
Jul 04, 2017Aspirant
RBK50 and Epson WP‑4535 scanner problems
New Orbi RBK50 system has arrived and all set up. It's working very nicely and the speed is astonishing! I've added the two wireless printers and printing works fine, but one of them, the Eps...
DarrenM
Jul 14, 2017Sr. NETGEAR Moderator
Hello sazzaf
Did you try connecting it to the other SSID that it can see?
DarrenM
- SazzaFJul 24, 2017Aspirant
Hi
Thanks for the reply - yes I did. Same problem.
Very odd.
- OrbiPhilipJul 24, 2017Luminary
In my case upgrading the Orbi to v1.12.0.18 and upgrading the printer firmware resolved the issue.
- Desmond_LauJul 24, 2017StarPls try to change 2.4G channel to below 22, some of printer doesn't support channel 13
