pobbard
May 05, 2019Tutor
RBK50 and FIOS gigabit - recurring loss of internet connectivity
Just over weeks ago, I installed an RBK50 in my home. Since then, my FIOS internet connection has acted unusually (for the very first time in 1.5 years, since we got FIOS), and I'm curious if the iss...
- May 23, 2019
Update on this issue:
I put the Orbi in AP mode, as recommended, a few weeks ago. The issue with my FIOS modem has not recurred since, so it seems likely that, for whatever reason, the double-NAT situation was causing the modem to choke.
Thanks again for all of the responses!
May 06, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
