pobbard
May 05, 2019Tutor
RBK50 and FIOS gigabit - recurring loss of internet connectivity
Just over weeks ago, I installed an RBK50 in my home. Since then, my FIOS internet connection has acted unusually (for the very first time in 1.5 years, since we got FIOS), and I'm curious if the iss...
- May 23, 2019
Update on this issue:
I put the Orbi in AP mode, as recommended, a few weeks ago. The issue with my FIOS modem has not recurred since, so it seems likely that, for whatever reason, the double-NAT situation was causing the modem to choke.
Thanks again for all of the responses!
pobbard
May 23, 2019Tutor
- plemansMay 23, 2019Guru - Experienced User
Glad to hear you have it working decent! ?Thanks for the update
- michaelkenwardMay 24, 2019Guru - Experienced User
That's good news.
Nice to know that the standard trick worked.
Your report might save someone else hours of grief.
