Latitudes33
Sep 24, 2018Aspirant
RBK50 and RBS50: constantly disconnecting and dropping internet
Running on 2.1.4.16.
I have an Orbi RBK50 connected through wired backhaul and an RBS50 connected wirelessly on my network. The system works great periodically, but on some days it constantly ...
Latitudes33
Sep 25, 2018Aspirant
The main router is downstairs and is probaby 30-40 ft from the wireless satellite. At times, the connection is good, the light shows a blue ring, but then it randomly drops and goes to magenta. Can only assume that this is software.
The wired satellite connected via ethernet cable has a connection status of poor on the attached devices page. When it works, the range seems fine, but it's constantly dropping devices.
Overall, I'm not trying to do anything beyond 5000 SQ ft and nothing outside.
michaelkenward
Sep 25, 2018Guru - Experienced User
If that is a wifi link from RBK50 to RBS50, it could be stretching things.
My RBR40 Orbi router (in access point mode) sits at the end of a Powerline ethernet link.
Why?
- Latitudes33Sep 25, 2018Aspirant
If it were too far, why would it show blue and 'good' status for several hours and then randomly drop off completely? The only way to get it back online is to do a full reset and re-add it.
