Latitudes33
Sep 25, 2018Aspirant
RBK50 and RBS50: constantly disconnecting and dropping internet
Running on 2.1.4.16.
I have an Orbi RBK50 connected through wired backhaul and an RBS50 connected wirelessly on my network. The system works great periodically, but on some days it constantly ...
Ken167
I faced similar problem before. I downgrade the firmware back to V2.1.4.10. Disable Daisy-Chain Topology , MU-MIMO and Fast Roaming at Advanced Wireless Settings. Then set a separate SSID for the 5 GHz network on your Orbi https://community.netgear.com/t5/Orbi/How-to-set-a-separate-SSID-for-the-5-GHz-network-on-your-Orbi/td-p/1396594
No more dropping afterward.
Hope it can help.
